Carb problem
Zenith 30VM downdraft carb (similar to that on a Nippy). The Ulster was running really well when it slowed and would not rev, only tick over. Checked that the fuel pump was working and fuel getting through. Removed the float bowl and the three jets, which were all clear. Blew the jets out anyway - and the holes in the bowl. Reassembled - and it revved cleanly. Has anyone had a similar problem or knows what the cause of this sudden-tickover situation might be?
My advice would be check the ignition system
(Yesterday, 11:59 PM)Tiger Wrote: My advice would be check the ignition system
Ran over that, too (especially with the previous problems) but a good fat spark at the plugs and from the coil, etc.
Condenser starting to fail / earth intermittent to same?
Hi Tony
I had a similar problem some time ago. It turned out to be a ‘floater’ in the fuel line. Tickover was fine but any draw on fuel would pull the offending bit of grit up the pipe and block the filter on the carb. The problem was that it was intermittent and happened just after I got a distance from home. Advice… blow through all the fuel lines.
(1 hour ago)Howard Wright Wrote: Hi Tony
Thanks Howard - that's a very good idea.
(2 hours ago)Slack Alice Wrote: Condenser starting to fail / earth intermittent to same?
Thanks. I've had lots of interesting condenser problems, so I carry a spare with wires fitted with clips, ready to try (plus, of course, a complete distributor and a bag of electrical bits and pieces).
