I am having to get a block re-bored following the seizure of the engine in our Pearl on the way to David Nightingale. I thought I would take the opportunity to de-rust the water jacket. I am considering using Bilt Hamber - Deox-C. Does anyone have any experience or alternative suggestions?
Martin
Lenton Treatments are a +1 from me. Excellent company. Used by many vehicle restorers including one of our own.
I took a suggestion from this forum and used oxalic acid.
The COSHH sheet made interesting reading!
22-01-2025, 02:13 PM
(This post was last modified: 22-01-2025, 02:14 PM by Chris KC.)
I've used citric acid before, with reasonable success - it's readily obtained in powder form for de-scaling kettles etc.
Perhaps slower, but a lot less nasty than oxalic.
As some trace will inevitably remain after flushing, it may be wise to neutralise it with an alkaline rinse.
Nowadays I'd be inclined to use a professional service, such as Lenton suggested above.
I have always found Oxalic acid to be one of the milder ones to use.
I have never tried to use it on car parts but have used it on boat timber work and GRP hulls for years.
I get it in a tub from my local GRP suppliers although my last tub went to work as they needed some to use on some Titanium.
Anybody tried Acetic acid?
Reasonably easily available and not too aggressive for home use I guess.
a short length of curtain wire, bicycle brake cable outer with the plastic off it or similar poked about and connected to an electric drill will knock off some of the flakey hard to get to bits between the cylinders
