3 hours ago
Hi All,
I'm on the hunt for taper pins for the gearbox levers which push on the bearing carrier to disengage the clutch. I've asked a couple of cherished suppliers who don't have these. I'm having some difficulty finding them here in the US. I think they might be No. 3 taper pins about 1.25 inches long. But I don't know what size the small end should be or how to determine the taper. The Austin part number is BH 85. As well, I need to source the washers/spacers which go on the lever shaft. These are part numbers BH87 and BH88.
Any sources are much appreciated.
Erich in Mukilteo
Erich in Mukilteo
