18-12-2024, 05:08 PM
(This post was last modified: 18-12-2024, 05:09 PM by Ruairidh Dunford.)
You will need to remove the valve, spring, collets, cup and the guide - you may be able to pull the guide up to allow enough room to remove the follower, unless the cam follower guides have been cut down.
Do you have a split follower?
Is it perhaps possible to withdraw the followers downwards into the crankcase if the camshaft is first removed?
I have swapped out a number of can followers over the years, using the method above.
You don’t normally need to remove the block.
You can also drift it down the way, I presume it is parallel guide, and replace it that way too.
Car type: ARQ Ruby
Cheers Ruairidh & Austin , looking at the 'Build Sheet' it definitely states the cam was "re-profiled" & I'm sure , but can't find any reference to the cam followers either being re-ground/replaced ???
Also, when checking the noise from the valve area I found at least one valve with a gap in excess of 0.030". It was also fitted with a Silicon block/crankcase gasket, which I guess is much thicker than the paper gasket used in the past. Currently the car is not accessible, but early in the New Year I will rearrange the workshop and check , and report my findings.
Austin inthe Shed, what did this tool look like ? as I may be able to replicate, if ??? the bronze guides are too high . Cheers.
