Twin side draft Zenith Carbs.
I have just got hold of a pair of tatty side draft Zenith Carbs.
They have spent several hours in the work ultrasonic cleaner which has got rid of most of the dirt and made most of the fasteners able to be undone.
The spacing is almost spot on for the Austin 7 block.
I have taken the bronze angled adaptors off to check the flange pattern against my twin carb tubular manifold.
The flanges on the manifold will need to be re made and the stubs shortened by about 5/8" to get them to fit under the bonnet.
The carb spacing can be altered on the joining link to suit the engine.
The good bit is the bore is a match to my manifold and the Venturi size is 20mm and the Venturi is removable on this type of carb but I expect they are corroded into place.
The spark arresters are brass so they can be made to look nice.
This will make for an unusual carb set up which will look more authentic than SU carbs.
Its possible these might have come off a Riley or MG of about 800cc
The fitted main jets are 80 so not very big for the Venturi size I have been unable to read the compensating jets yet.
The only downside with this set up is the throttle linkage is at the front of the engine so that will involve some sort of cunning bodgery to sort out.
Any one have any clues what car these might have been fitted to ??
As usual I might well have wasted a load of ££££ time and effort !!!
[Image: s-l960.jpg]
Someone posted a very similar pair on Facebook recently, also destined for an Austin Seven... I'll post a link if I can find it again.
Hi Nick,
Its probably me that posted !!!
Lol. That's the problem with using a pseudonym and using different photos. They looked s lot cleaner in the FB post.
Hi Nick.
Thats because I can take a picture on my phone and post it straight to Facebook Unlike this forum which I find almost impossible to put pictures on
The picture I posted here was borrowed from Ebay.
The Facebook ones were after 8 hours in the cleaner !!
I take a screen shot on my phone and crop it to reduce the resolution. Easier to post onto the forum when they are small.
Having owned a few Riley 9s I think your carbs are very likely from that application. As far as I know MG always used SU when unblown. I have had Solex, Zenith and SU on various Rileys.
