Wing Screw Thread ?
Hi,
Does anyone know what thread is on the wing screws that hold the opening windscreen in place.
I believe they're probably 5/16 but I've no idea if BSW or BSF.
John.
(11-09-2024, 05:43 PM)John P Wrote: Hi,
John.
BSF is easy to distinguish from BSW, the pitch of BSF is so much finer and easily recognised. These two BSF and BSW charts might help:
.jpg   zz BSF.jpg (Size: 202.64 KB / Downloads: 203)
.jpg   zz BSW.jpg (Size: 194.54 KB / Downloads: 202)
Sorry, probably didn't explain very clearly.
I haven't actually got the wing screws to measure but as I'm about to make the barrel nuts they screw into I need to know what thread they should be tapped.
John.
The thread is normally 5/16 BSW.
That's interesting because the replica ones supplied by Willie McKenzie (http://austinrepro.com/general) are BSW - but my '30 Chummy are 5/16 BSF. When the copies arrived, it was obvious that wouldn't fit, yet the barrels into which they screwed appeared to be the same as those from a '29 Chummy (apart from the thread, of course) and not something somebody had made (unless they had taken enormous care). Both threads work with the same efficiency so I suppose either would do if you are going to make your own wing nuts.
There is more tensile strength in a male BSF thread than in a BSW, but the BSW thread itself is stronger and will better resist getting stripped.
