Anyone used a cheap inductive tachometer?
Having now (almost) sorted out my ignition auto advance issues I would like to try to more accurately set up the 1 1/4 SU carburetor.
It looks like for both timing and carburetor adjustment it would be beneficial to have an accurate idea of the engine revs and I have seen on ebay relatively cheap inductive tachometers which appear to be battery powered and pick up the revs from an inductive loop around a plug lead.
Has anyone tried these and are they any good?   I'm a bit concerned that they may be wildly inaccurate or vulnerable to all the electrical interference created by an Austin engine.
John.
I had a go with one of those a while ago and whilst I didn't have anything to calibrate it against it seemed to read about right.
In my experience they don't work with mag engines. Way too much electrical noise!
Suffolk, UK
1925 Chummy
1934 Box
(07-08-2024, 09:45 PM)MartinH Wrote: In my experience they don't work with mag engines. Way too much electrical noise!
Probably should have said mine was a coil engine.
I would put more trust in a reputable timing light with an inductive rpm and degrees advance display
