28-06-2024, 11:59 AM
Does anyone know the thread size on input to a PA type governor speedo? Thanks.
Speedo threads
28-06-2024, 12:03 PM
3/4”x26.
28-06-2024, 08:44 PM
Are you also trying to find a die after a mazac failure repair, Alan?!
28-06-2024, 09:08 PM
No, I’m thinking about a reduction gearbox to correct speedo inaccuracy
29-06-2024, 09:25 AM
You could fit a bicycle speedo which is probably easier and cheaper to fit, I fitted them to our cars and found that two PA speedos read correctly and one 3 mph fast.
29-06-2024, 09:59 AM
I’ve got a bike speedo on the RL but I want the original speedo on the chummy to read correctly. It’s a belt drive that provides 3360 turns per mile into a 2240 instrument.
30-06-2024, 02:12 PM
If the chummy has it's original speedo why is the belt drive incompatible?
30-06-2024, 02:32 PM
I used original in the sense that I wanted the speedo that’s fitted to read correctly not to replace it with a bike speedo. The problem is it’s a belt driven system- that outputs 3360 turns per mile. The rather nice speedo head I have takes 2240tpm so it over reads somewhat. Options as I see it are new pulleys, a corrector box or just get better at mental arithmetic.
30-06-2024, 07:15 PM
My speedo works but it it so inaccurate I ignore it anyway. Top speed so far downhill with the win£ behind me is 57 mph.
