Pinion flange commonality?
Hi All
Could anyone please confirm that the pinion flange and thrust adjusting nut are the same on the 23-28 short nose banjo axle and the 28 -31 screw in axle?
Hi All
To answer my own question…..they are both the same. I’ve just taken off the flange on the van (with a short nose banjo axle). It is identical to the one on the screw in torque tube I have.
