Hello.
I would like to sort out the gear stick on my 29 chummy.
My question is how does the gear stick come apart to facilitate welding the ware on the casting.
Sorry if me questions seems a little
abrupt. I'm at work and trying to type on my mobile device.
Any help would be great thanks
Car type:
The ball change one needs the big hollow threaded retainer/ grub screw thing removed from underneath to expose the casting.
Not sure that’s right, Mike. The ball change lever withdraws from below, having first removed screw Bh 119 and threaded ring BH 118.
Silly me; of course it does!
Thanks for the information chaps..
The gearbox on my car is the older type gate-change lever.
With the grear stick in my hand, how does one take it apart! I can drill the rivets out of the reverse lift up rod thing, but that would only get me so far as the aluminium knob looks like its riveted to the stick. I have no idea how the ball is fixed on the selector end. I don't fancy cutting the gear lever in half just to make the repair..
Hi Colin
I think the shaft is peened over the aluminium ball.
I have replaced the old ball on my Special with a modern aluminium ball that came with an M8 females thread. By grinding the shaft to approximately 8mm I was able to use an 8 mm dye to thread it. Perhaps not for the purist but it worked for me.
It would help to see the problem if you could post several clear pictures of the area showing wear. There might be more than one solution to the problem.
