On mine part of the grease on the shoe problem was caused by a disintegrated gasket between the inner and outer parts of the hub allowing grease to wick through. So splitting the 2 at least lets you renew the gasket. Also then lots on here about not over greasing, or using sealed bearings.
I use a thinned down 14mm spark plug socket to remove the nut. Shearing the split pin has never caused a problem. Turn the socket down so it just fits inside the outer hub.
Bob
Are there not usually two small holes, opposite each other, in the threaded section of the outer hub to fit or remove the splitpin?
Car type: RP 1934
Hallo everyone,
Due to large amounts of grease that come through the gaskets and end up in the brake system, I would like to have a closer look at the gaskets themselves. Shall I use the typical paper gaskets or should they be replaced by some silicon stuff that I apply to both hubs?
Any recommendations or experiences?
Kind regards
Frank
To replace mine, which were leaking badly I used regular replacement paper ones with a very light smear of gasket gunk (I used Blue Hylomar) and followed the advice regarding cutting down on greasing. I did this about 5 years ago and having done my Spring service a few days ago I can confirm still not a smear of grease has got through.
