Well done for the first recorded installation of Trojan engine into an Austin Seven. It can only be a Trojan unless you have carried out some amazing surgery and put two cylinders of a Daimler sleeve valve engine under the bonnet. Either way, can we see the pictures please.
No - it's still got its original 'smokeless' engine - the smoke generator is extra - a soldered bean-can and an old radiator tap and not much else.
This takes me back to my teenage years...a pal had a 5cwt Ford van into which he installed an old ReDeX pump which injected into a nipple in the exhaust manifold. We would sit at traffic lights, give a squirt and watch a "waterline" of smoke wreathe its way up the sides and then blast off in a cloud on the green light. Happy days!
Very good Colin but is it legal. I seem to think that somewhere in the back of my mind there is an offence of creating excessive smoke.
John Mason.
30-03-2024, 11:02 AM
(This post was last modified: 30-03-2024, 11:06 AM by Malcolm Parker.)
All the above smoke stories pale into insignificance when one of the floating gudgeon pins in my Ulsteroid special gouged a groove in the cylinder during a trip to the Scottish Highlands. I changed the late cylinder head with an early head that had 18mm plugs to keep it going. It ended up doing 20 miles to the gallon of oil. It would still run and I set off on the way back to North Yorkshire, stopping in the Kwik Save in Kelso to buy a trolley load of cheap oil which at the time was £1.99 a gallon. I blasted over Carter Bar with Andy Hastings following in his similar Ulsteroid. Unfortunately he broke the crank trying to keep up by the Otterburn ranges and we both got a lift back home courtesy of the AA and RAC. Having followed in my smoke screen, Andy and the car looked black. Happy days.
I don't really wear a mask!
