Hi Everyone,
I'm just in the process of rebuilding the D-Type rear axle for my Nippy. I have checked the runout on the crown wheel this morning and I am getting a reading of between 3-4 thou.
I was just wondering if this was within the expected tolerance?
Thanks
Matthew
Matthew
3-4 thou sounds OK to me, Woodrow suggests less than 4.
Hi Howard
Thank you for clarifying that, its much appreciated.
Thanks
Matthew
It looks a little nose heavy for my liking, did you try to load up the Crownwheel at all when taking the markings? Was there any wear on the pinion bearing spacer? This is common and can affect meshing
Hi Ian
Thanks for your reply. I must admit that was my first impression.
I did load the crown wheel as best as I could and from memory the bearing spacer wasn't badly worn, having said that I don't have a comparison to look at.
I think I might tweak the adjusters slightly to try and bring it more into mesh and then see what that effect that produces.
I'll keep the thread updated.
Thanks
Matthew
You may need to adjust the shims as well
Hi Ian
Yes, that is the next thing I am going to look at. I was hoping to avoid increasing/decreasing the shim size because the one bearing I haven't replaced is the pinion roller bearing. I'm conscious that this will have worn into a particular area on the internal surface of the outer race so moving the pinion in this plain might create a separate issue. I'll try it and let you know the results.
Thanks
Matthew
Hi Mathew,
if the roller bearing is worn enough to be affected by shimming the pinion it should be replaced. The pinion bearings are very important to A7 axle survival.
I'm sure that there is a living to be made for a new Cherished Supplier who deals exclusively in rebuilding A7 back axles. It's a dark art, frightening to many owners, and keeps many cars languishing unused in garages.
