Flasher unit wiring
I’m no electrician and wiring up my car     following the Dorset A7 diagram I have the indicators working on the Lucas sd84 switch but the durite flasher 0-606-00 I have has different connection numbering.l don’t want to blow it up ,any help please.
The durite connections are marked + C and and an R ?
Is this what you are looking for Dave?
The diagram came with it,just that I don’t understand it !
Hi Dave,
Positive feed goes into +
Output to flashers (switch) from C
Dashboard repeater from R
Thanks R confident to put the wires to it now.
