18-01-2024, 08:23 PM
I’m just relocating my 6v battery to under the passenger seat and would welcome ideas of how best to secure it in place please
Battery clamping
18-01-2024, 08:52 PM
Mine has a length of bar 1/4" with a right angle on the bottom end. It is passed through the drain hole in the battery box and up to & through a piece of angled alloy sheet that fits onto the top of the battery. The top end of the bar is threaded and locks into place with a double nut. Been like that since time mint imperial and works well. I use a wooden spacer to keep the battery firm up against the side of the battery box. I'll get you a pic tomorrow.
18-01-2024, 09:43 PM
Mine is just dropped in the hole. Can't say I've ever rolled the car to see what would happen.
What I would suggest is a loop of webbing or similar which passes under its base, which can then act as a handle for lifting it out with ease.
18-01-2024, 10:16 PM
(This post was last modified: 18-01-2024, 10:17 PM by Ivor Hawkins.)
Yep, mine’s just dropped in the hole, bars, clamps and pieces of would add weight and would slow it down…
18-01-2024, 10:26 PM
(18-01-2024, 09:43 PM)Chris KC Wrote: Mine is just dropped in the hole. Can't say I've ever rolled the car to see what would happen. I have rolled a Seven and I've seen what can happen with a battery that's not clamped down. I wouldn't recommend it ![]() Endorse the advice regarding the webbing loop. Steve
18-01-2024, 11:08 PM
(This post was last modified: 18-01-2024, 11:09 PM by David Cochrane.)
18-01-2024, 11:13 PM
In the car industry we have test dummies for that sort of thing. In the VSCC we have ……….
19-01-2024, 09:31 AM
Hi Peter
This is the strapping arrangement for the under passenger seat battery on my Special. My RK has a similar but webbed strap. Cheers Howard ![]()
19-01-2024, 09:53 AM
19-01-2024, 10:38 AM
(This post was last modified: 19-01-2024, 10:39 AM by Reckless Rat.)
Very posh is that, Howard. You put me to shame... (the extra wiring is for my 6v to 12v converter for phone charging etc)
