Measure the pipe for the right size of grommet and drill a hole to match the grommet?
Duncan, there is no pipe at present, so was wondering what the original factory diameter was.
Thanks,
Stephen
Hi Steve
The pipe on my car is about 1/4” (it’s squishy rubber so difficult to measure exactly). It is reproduction bought from one of our Cherished suppliers.
Hope that helps
Thanks Tony. From what I can see and extrapolate from photos the hole would appear to be 1/2" diameter. I'll turn something up on the lathe to do the job.
Stephen
Steve. I think you'll find the diameter is 7/16". I can let you have a brass grommet FOC if it helps.
Parazine. I had a batch made some time back but mine were not as long as yours and closer to the original pattern. I didn't take the risk to Ni plate as I worried about the threads and whether the two halves would screw together after the plate.
Hi Chris, thanks for the information and your generous offer. I'll go with 7/16" and open it up to 1/2" if need be. I need to turn up a batch of brass grommets anyway for the wiring when the time comes.
Cheers,
Stephen
