Hi all. Apologies for not putting this in sales and wants... does anyone have a hub puller on the shelf with stripped threads? I have a particularly stubborn back axle and don't want to weld a decent one onto the already damaged threads on the hub.
23-09-2023, 10:07 AM
(This post was last modified: 23-09-2023, 10:47 AM by Reckless Rat.)
I've got one but you'll have to come to France to fetch it. It will cost you more than it's worth for postal charges and customs post youknowwhatxit
Hi Nick,
I have one that is as you described.
Let me know where to send it.
Peter Pearson
How about cutting the hub off ?
Hi Nick
That will be the last resort, but I will if need be. I'm far to parsimonious to waste a good hub, and always consider that they must be very well lapped when they won't separate without a fight!
Last time I had this problem, I did eventually achieve separation of the hub (or taper) welding the puller over the mangled threads. The hubs are still in service on my ORT. I have been able to remove plenty of hubs since with the remains of the old puller, cut in half and welded to some gash steel to create a triangular ring that is clamped very tight at the rear of the thread allowing a 3 legged puller to be used. Having destroyed that with a hydraulic puller, I'll probably make another with the knackered puller I use to free this one up...
