20-09-2023, 04:41 PM
Does anyone know if there is a reliable source of dynamo drive gears?
Cheers Denis S
Cheers Denis S
Dynamo drive gear
Cheers Denis S
Funny you should ask as I wanted to ask if anyone knew if these were genuine Austin parts and therefore presumably OK.
https://www.ebay.co.uk/itm/334971273218?...p_homepage Sorry, I should have clarified that the ones I am querying are actually distributor drive gears.
20-09-2023, 06:35 PM
(This post was last modified: 20-09-2023, 06:36 PM by Denis Sweeney.)
I believe our regular trusted suppliers have good replicas of the distributor drive gears but cannot find any dynamo drive gears.
I have a dynamo that has been refurbished and tested but the drive gear was not included and needs replacing
20-09-2023, 06:53 PM
Hi
Dave Dye, AKA ‘Austin in the shed on this forum’ supplied me with a set of crank, cam and distributor gears about two years ago. They are first class and going well after 4000 miles. Cheers Howard |
