Steel Magneto Camshaft Timing Gear
I don't suppose that anyone has a new steel timing gear with a taper bore for a magneto camshaft going surplus?
Thanks
Hi Charles,
I belive that Dave Dye might be able to help you with a new one.
(09-08-2023, 04:59 PM)dickie65 Wrote: Hi Charles,
Sadly not
c
(08-08-2023, 06:22 PM)Charles P Wrote: I don't suppose that anyone has a new steel timing gear with a taper bore for a magneto camshaft going surplus?
Thanks
Do you have the old gear to act as a pattern?
Thanks
Yes, I have a gear with the wrong taper. I was just seeing if there was a short cut that avoided me me machining a new taper centre for a steel gear that I have. Cleary I'll have to go that way.
Charles
