25-07-2023, 06:59 PM
Does anyone have a pattern for a RN headlining?
RN Headlining
25-07-2023, 09:24 PM
I no longer have a sunroof, it was removed a long while ago and cannot be reinstated as rails have been removed. To replace the rails will be cost prohibitive (unless someone knows differently) so I am looking for a pattern with no sunroof
26-07-2023, 08:12 AM
"cannot be reinstated it " - nothing is beyond a good panel beater / coach builder. It's just the cost of doing it and re-painting afterwards. The drawings are available for the sun roof itself, not sure about the slides, but I had to make bits of slide up many years ago when I restored our RN.
26-07-2023, 08:18 AM
Agreed everything is achievable but I have to draw a line somewhere and spending £2000 - £3000 on a sunroof I could not afford.
26-07-2023, 09:17 AM
Ah that can be a problem particularly if the drain over the windscreen has corroded away
27-07-2023, 06:03 PM
As is quite often the case, the Archive web site could be your friend...
https://archive.a7ca.org/collections/tec...em/TD0191/? hth...
27-07-2023, 08:58 PM
Unfortunately those details are for a de lux car with sunshine roof.
28-07-2023, 10:15 AM
I've checked my register of RN saloons and have found there are 15 fixed models and I haven't got a photo of the headlining of any of them.
29-07-2023, 08:45 AM
Has anyone any recommended books for interior trimming that would also show how to construct and fit a headlining?
