Chassis dimensions
hi all, What is the easiest dimension to check on a bare chassis to determine if it is short or long wheelbase?
thanks
Colin
The Archive holds engineering drawings for the various chassis, so a look there would be a good place to start. As an example...
https://archive.a7ca.org/collections/tec...em/TD0014/?
hth...
Quickest way is to count the holes behind the handbrake fixing. 9 is a long chassis:
.jpg   lwb chassis2.jpg (Size: 100.96 KB / Downloads: 267)
7 is a short chassis.
.jpg   SWB chassis2.jpg (Size: 55.07 KB / Downloads: 266)
Thanks both - that was a great help.
Just noticed, very late chassis with rod brakes - and therefore a modified handbrake mounting bracket - has eight holes.
(The front one of the nine on the LWB chassis is missing.)
