I am just about to overhaul the shock absorbers on the Chummy that I suspect have not been touched since the car was restored 40 years ago, and are probably too tight, anyway. I know the beech discs should be soaked in liquid tallow and I think I could get some locally. However, I do have to hand some coconut oil that I would imagine has the same sort of qualities.
Any thoughts on the use of Coconut oil instead of tallow from the combined mind?
Hugh
I would just give them a thin smear of grease.
If you do want tallow then it is used as a flux in leaded glass making and can be bought in candle type form.
Car type: ARQ Ruby July 1936
I believe Tallow is rendered beef fat or dripping as my mother called it, iand beef dripping was available at my local supermarket.
15-06-2023, 09:28 AM
(This post was last modified: 15-06-2023, 09:29 AM by Reckless Rat.)
Treat yourself to a tin of Duck Confit. Drain off the fat and put it in the fridge. Enjoy the Duck, then use the fat on your discs. It's also excellent for cooking your roast potatoes.
I have a small tin of tallow I use for lubricating taps and dies - acquired for a modest price from eBay.
Well....
So whilst mulling on the Coconut oil option (which I still think would be viable) or I have a tin of duck fat available as well having just had some duck confir for dinner (bought in France - too pricey over here!) I decided to start on the overhaul. The first thing was to disconnect the ends of the rear arms from the spring pins. At this point, on both sides, the arms gently dropped to the ground under their own weight!
Eh?!?
So, far from them being overtightened, as I suspected as it bounced around all over the road, it was quite the reverse - and bounced around all over the road!
The movement of the arms felt quite smooth so I decided not to disturb the business end. The rears I set to 12ftlbs on a spring balance, the front (which was in exactly the same condition) I set to a nominal 10. That's what the Cabriolet s set to, anyway, and is well behaved. After I have cooled down, I shall take it out for a spin and see what has changed. Surely, something will have!
Problem is Hugh if you use beef dripping, mutton fat or confit of duck you will have all the dogs in the neighborhood running after you next time you’re out for a spin.
Charles
