Old (modern) Voltage Regulator Identification
We have this old (modern) voltage regulator which was removed from an A7 special. Unfortunately we have no note of the wiring connections. Please can someone with a similar regulator tell me the wiring connections? Does anyone recognise this device? Thank you!
Matt,
   it is a J.G. conversion by Dave Lindsley unit.
Yes, a "JG 12 Volt Electronic Regulator" from the early 1980's.
But is it a positive or a negative type? Both were available.
.png   Screenshot 2023-03-22 at 20.42.14.png (Size: 478.2 KB / Downloads: 244)
The first photo from Matt has an 'N' so presumable negative earth.
Absolutely blooming fantastic. You‘ve made my day! THANK YOU
Make sure that you earth the case, I made an error when I refitted mine on my timber bodied marine special. No output until I gave it an earth return.
(22-03-2023, 10:09 PM)andrew34ruby Wrote: The first photo from Matt has an 'N' so presumable negative earth.
Presume nothing! It may mean negative charge.
Are there any other markings on the case?
Treat it with care because they are no longer available.
