racing engine for sale
Raced at Bonneville Salt Flats for 6 years .   37'  3  MAIN CASE MODIFIED FOR 2 MAIN  HADLEY CRANK   (standard bearings) ..  Front lip repaired .. Case to block  extra support w/ 2 studs ..  ARP studs w/ thread inserts through out ..  Gear oil pump (90 #)  w/ external filter..  .060 custom forged pistons w/ wedge tops  (8-1 compression ratio)  w/ Total Seal rings ..  Custom cylinder head for piston fit  w/  ARP 3/8" studs /washers / 12 point nuts
.jpg   DSCN2670 - Copy.JPG (Size: 119.24 KB / Downloads: 592)
.jpg   DSCN3486.JPG (Size: 123.36 KB / Downloads: 584)
.jpg   DSCN2670 - Copy.JPG (Size: 119.24 KB / Downloads: 592) ..  Ali large size oil pan .. Custom off center / lightened  followers for timing adjust between intake / exhaust .. Adjustable cam gear made from new cam gear ..  Ford Zetec stainless oversize tuliped head valves w/ custom springs (45# / 90#)  , titanium retainers ..  side valve cover has external oiling for valve  springs ..  Manifold  stainless steel set up for TURBO  w/ water and oil cooling .  Fuel injection at ports ..  Flywheel machined for 60 minus 2 notches  for deadfire 2 coil  Electromotive  ignition w control box / wiring  and all sensors for computor control of engine systems .  Call   520 591 6318  ( Tucson , Az.  USA ) for questions or  E mail              SCAHANDYGUY@GMAIL.COM       NO CAM  or RODS ..  More pics available  ,   STEVE
.jpg   DSCN1262.JPG (Size: 122.61 KB / Downloads: 575)
What an incredible amount of technology all packed into an engine designed to take Fred Bloggs to the local market town!
I think if I put that in my box saloon and dropped the clutch, I would be looking at a 12 second quarter mile!
Extraordinary work!
The very thing to drop into the Ruby and take to Pendine!
No difficulty in keeping up with modern traffic, although I am not sure that my cars brakes, general handling or indeed my nerves would stand it!
Very nice and probably not at all cheap, but shouldn't this be in "Sales & Wants". Over to the Mods.
(23-02-2023, 09:55 AM)Reckless Rat Wrote: Very nice and probably not at all cheap, but shouldn't this be in "Sales & Wants". Over to the Mods.
 Or bring back pedants corner  Tongue Tongue Tongue
Rekkers is correct, of course, but I’m not sure how many people check out the sales and wants section...on a banjo forum I use, they allow people to post a link to their ads on the general forum for better exposure, which may be an option...
Is the banjo forum for back axle sales and wants, or do you and Tom Langham compare Austin Seven notes spread on your music stands?
Haha! I think Tom and I may be the only two loonies who drive Austin Sevens and play the banjo!
