Hello all, I'm after a correct starter motor of the late vintage type between the bacon slicer type and the side crankcase mounted type. I understand that this type isn't interchangeable with the other types, but I'm not sure which starter model type I should be looking for? It'd also be useful to know if there's an easy visual identification for this sort?
On a semi related note I'm also after a floor mounted starter button. In the absence of an original, are there any 'modern' types that are known to fit? I wondered if the early mini ones would be about right but I think they're too small.
Any input much appreciated!
Rupert
Have you checked Tony Betts' catalogue? (Seven County Austins)
I'm pretty sure he had a floor-mounted starter button for sale.
Thanks all that's all really helpful.
Very happy to be corrected but I had thought that the CAV35 was not correct as that was fitted to the other versions and therefore spins in the wrong direction?
22-02-2023, 09:36 PM
(This post was last modified: 22-02-2023, 09:37 PM by David Stepney.
Edit Reason: Bloody autocorrect AGAIN!
If the starter were turned round to face the front and swapped to the nearside of the engine, it would still turn the engine the correct way i.e. anti-clockwise when viewed from the driving seat.
The starter button bought from a local motor factor masqueraded under a number of names and part numbers for Minis and series 1 Landies amongst other things, but seems to work perfectly well.
Tee forward facing and rear facing starter motors are not interchangeable, otherwise life would b much easier!
Quite right Howard except the one on the RN I bought 40 years ago, it looked correct but the engine would't start because it was running the wrong way.
