05-02-2023, 10:17 AM
Hole in the Floor
05-02-2023, 10:20 AM
It is to adjust the brake pedal height, wing nut on brake rod. Only used on Ruby based models.
05-02-2023, 10:34 AM
Thanks. My floor's been replaced with sheet steel - from the side of a fridge or similar - so this feature is missing.
05-02-2023, 03:51 PM
On my Ruby the cover for the hole is a circular piece of wood with a shoulder machined into it to prevent it falling through the hole. I don’t know if this is standard or if a previous owner has made it. The hole under the rear seat to lubricate the bearing between torque tube and prop shaft is a metal cover.
John Mason.
05-02-2023, 04:45 PM
Somewhere else water can get in? And needs a 'round tuit' to fill the hole?
05-02-2023, 05:07 PM
I've been on the look-out for one of them there round tuits for more years than I can remember
05-02-2023, 05:54 PM
there is a wooden hole filler in my cabriolet it looks to have been there from new regards to all Rob.
05-02-2023, 06:02 PM
Good lord, if the ford is deep enough for water to enter through the brake access hatch, serious challenges are about to present themselves.
06-02-2023, 11:15 AM
09-02-2023, 02:45 AM
I have a square TUIT.......
For those that never get around TUIT Peter |
