18-01-2023, 04:16 AM
I rebuilt the gearbox and I find that at times 4th gear is hard to engage. If I release the clutch and then try again it is the same. The problem seems to be a random one, sometimes all is smooth, other times it balks and I almost need to force it into gear. Any suggestions please.
I do need to attend to the gearbox at some stage as I did not replace the selector springs and balls and it immediately jumps out of 3rd gear on the overrun.
Graham
Graham
Slowly rebuilding a '34 RP
