Is it just me, or does anyone else find that after 20/30 miles their fingers get somewhat tingly or numb? It's not something that occurs all the time possibly as a result of constant revs / road speed. My engine ,solid mounting to chassis, may be the cause, does it happen with the later rubber mounting set up?
Can you speak up? I can't hear you!
Joking aside I didn't find it a problem in my RP which has a later rubber mounted crankcase - I was doing 250 miles plus a day for 8 days when I did the Santiago run.
This problem is caused by poor balance of the engine.
The steering box is bolted to the chassis next the the rear O/S engine mount so engine vibrations are transmitted onto the steering column.
When I rebuilt the engine in our car with a Phoenix crank I had the crank, rods, flywheel & clutch balanced. Now no problem ,even after driving long distances - 150 miles +.
My car has solid engine mounting and, yes the vibration does travel up to the steering wheel as the lightest of a buzz. I also find numbness coming into the fingers particularly in my right hand after say, an hour at the wheel. I find that wearing a pair of gloves helps a great deal as it tends to damp out the vibrations, and always keep a pair of decent warm gloves in the car.
Same here. Reynauds disease I think it's called
I think what is being talked about is actually called 'Vibration White Finger'...
It is 'Vibration White Finger'. Jim's suggestion that it relates to engine balance fits as the engine in my Saloon is as it came to me and doesn't appear to have had any balancing. I don't seem to get the issue with cars fitted with engines I've built that have been balanced. I've a re-built and balanced engine sitting, waiting, in the garage. Perhaps I should fit it to the Saloon....
