Yamaha Pistons - Long memories needed
Can anyone with a long memory recall which Yamaha piston has been used in a A7 in years gone by?
Thanks
Charles
Do mean Yamaha or Honda?
Yamaha bike pistons .
Not the Honda generator ones
C
Isn't the trouble with modern bike pistons that they are designed for over-square engines with a very short stroke?  I think there have been problems resulting from the use of such pistons in Austin 7 engines.
(30-10-2022, 03:05 PM)Malcolm Parker Wrote: Isn't the trouble with modern bike pistons that they are designed for over-square engines with a very short stroke?  I think there have been problems resulting from the use of such pistons in Austin 7 engines.
Thanks Malcolm. It was the piston rings I was interested in, but that's an even odder question to ask
Charles
Hi Charles,
Not sure if this is of any help.
I have used Honda 500/550 Four pisons and of course their rings and have had good results. These engines are moderate to high revving. I think spares (rings) are still available from specialists.
YAMAHA ybr125 If I recall correctly is right for a A7 bore. Rusty old memory though so double-check
Charlies,  Yamaha piston rings for slipper pistons available in std 4GA-11603-00  +.5mm 4GA-11605-00 +1mm 4GA-11607-00  57mm, 57.5mm 58mm. From Yamaha dealers fitted to XJ550 and XT125, sent email but bounced back, I have another supplier if you can't find them email me. Terry.
Ah yes, the xj 900 is 58 mm iirc
Thanks Terry and Joe. Useful information
Terry, I changed my email address a while back and the redirection must have run out
Charles
