Headlights
Might anyone happen to know if the large nuts that retain headlights to brackets are common?
They look to be a fine cycle type thread on scuttle type headlights.
Even better might someone know where these can be purchased?
Thank you
Hi Spoonbill
I think they are called headlight stem nuts. The Cherished suppliers have them in stock.  I believe they are BSC thread.
Thank you Howard, always helps find them if you call them by the right name!
