I don't suppose anyone has a dimensioned drawing of an Ulster, Nippy or other sports type head?
A late Ruby could also be a good start point
Thanks
Charles
Car type:
so is this a blank you have come across, or have you started from scratch with an aim in mind?
I can pm you the centers from memory for the studs,water transfers if you like.
As you will know machining the combustion chambers on a manual machine is the difficult bit.
Car type: 1937 Austin 7 Nippy
Hi Charles,
I've just sent you a private message.
Best wishes,
Nick
I might have a drawing somewhere Charles. The prototype went with the marriott and I've been trying to reacquire it (in case anyone has recently bought a new machined head covered in sharpie annotations).
It might be a bit drastic though...
That looks rather like my Dante head that I have never dared to use!
