What is the correct method of attaching plug leads to a magneto with thumbscrew type posts on the distributor head. I can’t believe you have to wrap the bare wire around the terminal.
Alan, I vaguely recall that you almost do but there's a sort of eyelet thingummy rather like a cup washer that goes between the loop of wire and the thumbscrew. The other answer might be to screw a small screw eye into the end of the ht lead.
I’ve always used screw in closed cup hooks that bear a design similarity with the hooks that used to be on the end of net curtain cord. They wind into the copper core of the HT cable
Slightly different application but the dynamo connections on my car are rather like stuartu describes. Basically there is a brass cup washer which is castellated around the circumference. The cable is stripped back, twisted together and then laid around the cup to form an eyelet. Another plain brass washer then sits on top of the stripped cable and finally the castellation's are folded over to form a ring.[b][url=https://www.austinsevenfriends.co.uk/forum/member.php?action=profile&uid=47][/url][/b]
