I renewed my worn floatbowl needle valve recently(thank you Robert Foreman four directions to Southern Carburators web site). This has stopped the flooding problem,but the motor won’t now start without a spray of Aero Start . I am using a Solex M V 30 carburettor with 21 mm choke , 105 main jet ,55 slow running jet and a 47 gm float . I tried a 42 gm float ,this gave a fuel level just lower than the 3 mm level the Solex manual suggests. I hope someone can give me a remedy
11-08-2022, 08:17 AM
(This post was last modified: 11-08-2022, 08:22 AM by Gordon england brooklands.)
Hi Charles , thanks for the reply . The 42 g float gives level just below 3mm . The 47 g is 1 mm lower than rim of main jet mount , without the flooding problem . With the 47g float the motor runs OK but won’t start without a Spray of Aero start . The motor won’t idle below 1100 rpm , the motor is fitted with a Dante aluminium head a moderate camshaft , 28mm inlet valves and Phoenix pressurised c/shaft and con rods and J P pistons
Charles , The motor has been built and running well until the new needle valve was replaced starting was not easy but now it won’t start without aero start
GEB,
I'd get back to Robert - he's the guru.
My Brooklands has the same settings and is fine, although a tad rich.
Chris
