BA Threads
@page { size: 21cm 29.7cm; margin: 2cm } p { line-height: 115%; margin-bottom: 0.25cm; background: transparent }
Hi, does anyone know the Standard Thread of the fixed ignition point on a DJ4 Distributor. Information available suggests BA sizes were in use in the 1930s. Thanks in anticipation.
I use a BA Spanner on my points.
I suspect its a 4 BA but I would need to confirn it.
0 BA is a large thread size and the numbers go up as the diameter goes down.
A useful chart for tapping drill sizes for BA threads: https://maccmodels.co.uk/ba-size-chart/
A complete specification chart here: https://www.ring-plug-thread-gages.com/P...-data.html
The early fixed contact is 4 BA and the late fixed contact is 3 BA.
Many thanks to everyone for their response. It is much appreciated.
If anyone needs any BA Taps and Dies I have plenty spare, I will swap for 7 bits too
