Rad cowl strengthening bar
I recall there was a discussion recently about a bar that fits across the back of the radiator and strengthens the cowl. A search doesn't seem to turn up what I recall. I'll note that Chris Gould's Ulster book says that the clearance between the radiator and fan should be 1/8th inch which doesn't seem to allow enough room.
Erich in Seattle
The bar is arched to clear the fan, I don't have a picture to hand but can take one
Thank you, Ian. I would like to see it, along with rough dimensions.
Best,
Erich
I posted this in your thread “wing supports for Ulster reps” thread Erich.
The brace depicted in Ruairidh's picture is made from 1 5/8" x 1/8" mild steel flat bar, and the bow is 2'' high, easy enough to make.
....and if you can't, Rod Yates has them ready to bend to suit your aperture...
This is a strenthening bar on an A7 Arrow 2 seater 1931.
Just wondering if Gordon England cars with
headlamps bolted directly to the cowl
Used a strengthening bar?
My car has CAV lamps( NOS!) but I still
Have to fit them.
Bill G
Aka AllAlloyCup
(31-01-2018, 11:54 AM)AllAlloyCup Wrote: Just wondering if Gordon England cars with
See here Bill:
https://gordonenglandregister.wordpress....rousel-716
Thank you all.
Best,
Erich
