“Canterbury” is in Kent. Is that anywhere near Dover? Is it as close as you can get to Dover due to tailbacks on the A2 and everywhere else in the Garden of England? I am impressed by the use of special machinery that can staple carpet onto steelwork. Maybe it is hydraulic or huge staple press driven by line shafting, perhaps built by AF Craig in Paisley in about 1907. Perhaps not.
Looks like some/all of a boat tail body, has it been lengthened in the scuttle to fit LWB chassis?
Certainly longer in the scuttle than other high rad boat tails I've seen.
The windscreen is unmolested, and will be unique to the boat tail in terms of width.
I had a '32 box registered in Kent on a 3 + 3. But I think '31 unlikely
"Car Number 25, Original Plate".
That's curious, as number 25 would place it as very early 1929 at the latest, that registration dates from March 1933 - at least twelve months after the last boat-tail was built - and the car displays characteristics mostly relating to late 1931!
There's undoubtedly elements of an original boat-tail somewhere in the car, but champions of originality might well be advised to steer clear; having said that, it might be a worth-while buy at the advertised price, but a personal inspection is probably a necessary precaution!
Car type:
13-05-2022, 10:18 AM
(This post was last modified: 13-05-2022, 10:19 AM by JonE.)
It's on the Register as a yellow RP.
Seriously, wouldn't trading standards be interested in that description?
Car type: Special 1930 chassis
decent price I'd say, then body it how you want :-)
Its certainly an attractive 2 seater open car.
Thank you to who ever added the price and description, ooops forgot the inverted commas for “description.” The text immediately identifies the vendor, and as mentioned above the price is almost sensible for a rebody project. But no underbonnet images. HC head, ill fitted SU, Reliant engine? A suitably set up 1172 could produce a good trialling machine. Then again….. back to the workshop.
