Could anyone tell me if this is possible and how I should go about it please?
I need to fit suppressed HT leads to a project with a DK4 cap - I would prefer to use the brass crimped ends at the plug too, any practical experience in this area would be very welcome.
Thank you Howard - can you take a photo of the acorn end for me please?
I use a length of solid copper wire from a mains cable about 1-1/2" long. Push it up inside the cable then bend it over 90 degrees and bend it round in a circle flat against the end of the acorn.
has been working well for us for a long time.
That sounds perfect - have/can you do the same at the spark plug end as well Jim?
Very helpful - thank you!
Car type: Austin 7 RN 1931
Hi Howard
Do you use the brass crimped end on the plug end.
I had problems with LED indicators which I eventually rectified by using suppressor caps. Whilst it solved the problem I don't like the appearance, I would prefer to use the proper brass ends
I just stripped the insulation and poked the grey stringy bit (technical term) through the brass washers. I think on the plug end I would have done the same and folded it back onto the outside of the lead before crushing the crimp, much as you would with copper... I like the idea of a strand of copper to beef it up.
