11-02-2022, 03:53 PM
(This post was last modified: 11-02-2022, 03:54 PM by Reckless Rat.)
I would bin that and put it down to "caveat emptor". It's cracked all the way across from the camshaft to the oil gallery. More trouble than it's worth.
Might make a decent paperweight though.
I have a crank case with a very similar crack. It was caused by rigid bolting the engine in a trials car.
Is not worth welding put it in the scrap
11-02-2022, 06:50 PM
(This post was last modified: 11-02-2022, 06:55 PM by Austin in the Shed.
Edit Reason: Add content
Scrap I'm afraid,even if someone weld it the crankcase will be distorted.
I'm looking at salvaging one now,not a stripped thread on it but a really badly bodged front bearing flange where 5/16 bolts have been fitted to fix the bearings.
From experience bodged sump and strainer,most other threads on the extremities (welding up) but down the sides and top face is trouble.
I bought 3 at 750 Beaulieu for conversion,only one was very good but knew the other 2 were marginal.
As others, it's scrap. The only way to save it is by laser welding that won't distort it further but the cost will be rather more than a replacement. I think we can all say, been there, done that at some time.
By chance I've just found a local Tig welding company thats into motor mods and repairs too, as it was originally bought for a low comp cooking engine, I'm going to let them loose on this one, if it turns moody the I've got a 'dummy motor' for my new Motor Lodge.
Even Tigging that will be awkward amd messy
I have had a Nippy Crankcase Laser welded it cost quite a lot of money and it only had a hole in the side.
Look for another crankcase.
Scrap? Just put aside. Myriads of items have been needlessly scrapped. many non welding ways around the filter drilling breakages and the front flange.
I wonder how many stud cracks are due pliant gaskets and/or excessive torques. With only two bearings distortion is far less a problem than with other enginet, although bearing housings should be round and the centre camshaft aligned by one means or another.
