Brakes
Hi everyone
1934 Rp
I've just renewed all the linings and new rear cables and pivots.
Two things :
1st :When I reverse out of the garage there's awful brake snatch through the pedal but not going forwards, when I've driven it 15 metres it's fine in reverse  ?
2nd : It pulls to the left when braking firmly , I have plenty of slack in the cables  ?
Because I've put new cables on should I have undone the brass adjusters for handbrake and for footbrake  ?
Check front spring shackles ant the radius arm mounting for wear.
