15-12-2021, 11:27 PM
I am reassembling my Ruby steering box after stripping and cleaning it, but I am having trouble adjusting it so that it turns smoothly. I must be doing something wrong, but I am not sure what. Any suggestions?
This is what I have done so far:
With the gear wheel bolted to the arm and assembled on the outer cover, I fitted the cover to the box to check for end play on the arm. I had the gasket in place and tightened the nuts to 8lbft. The arm turned freely without end play.
I removed the outer cover and screwed the column into the box, ensuring that it turned smoothly without any end play.
I then bolted the outer cover back on again to 8lbft, ensuring the cover was slid as far back as possible to give the greatest initial clearance.
As soon as I bolt the cover up with the column in place, it becomes impossible to turn the column. I have the steering wheel attached to ensure that I have adequate leverage.
Everything is greased.
Can anyone shed any light on what I have done?
Regards,
Jamie.
Regards,
Jamie.
