Do you have a dusty row of old jam jars in the garage?
Mine go back three generations. They contain a chaotic mixture of fasteners - all shapes, sizes and threads.
Car type:
my entire attempt at A7 organisation is based around value Peanut Butter containers. White tops so you can write on.
Labels? I just look through the glass. If I want to find something, I might have to shake them a bit - and if that fails, tip the jar out into a shoe box lid.
I've got rows of old dried milk cartons - all carefully sorted; the trouble is I can't now remember which cars they were for, so I now spend ages going through UNF nuts looking for a suitable BSF one, or vice versa. Sometimes I recognise, for example, a Triumph Herald window winder bracket, so know not to look in that one, but I'm not usually so lucky!
I have a huge range of different tins and jars with no identification as to what’s in them...I’ve been looking for a metal Speedex badge on and off for the past six months, but I did find all the bits for a Lucas vacuum wiper motor...
Car type:
glad that's still on your mind, Ivor :-)
My attempt at separating 5/16 things from metric has been woeful. I now have pot for standard metric of the nearest looking size, pot for BSF, and....huge bucket for "odd" (which are always the best looking ones)....
I also use white peanut butter tubs but I'm looking for small containers to fill the wasted gaps between them!
I use the glass jars that Lidl use for table sauces. They have gold coloured lids that you can write on with a black marker pen. They are kept in a Bisley multi drawer steel cabinet of a type that every secretary used to have to contain stationery, letterheads, envelopes etc. When you open a drawer there will be about a dozen jars looking at you and the system works very well. I still have several old St Bruno baccy tins which don't work quite so well. The lids can take some shifting and I never know what I will find, usually rusty old tin tacks.
Trouble is when I organise and tidy up. I can't find anything.
