Car type:
Are the rad shells on an AE tourer and AD Tourer are the same as RK Saloon?
(and perhaps the same as the same as the 34-36 sports models?)
I thought they were, but overlaying the technical drawings the saloon bonnet line seems higher, hence question.
thanks
AD, AE and RK all use the same rad shell - so far as I know Jon.
I understand they are the same as the later sports as well (with some light bracket holes drilled).
The AD shell was black painted steel and shorter between mid 1926 and September 1928 ,at this time the magneto engine was superceded by the coil engine and the taller Nickel plated shell. The R saloon and RK saloon were produced together for a short time , both with nickel shells (till around late October 1928) to use up stock.
Cheers Steve Hainsworth
Car type:
Tony - that is really useful to know. I'll email thanks directly too.
The horizontal bonnet line thing is interesting. Those Nippy cars which have found it somehow (whether that be through raising cowhorn packing or engine mounts or whatever) definitely have more presence/a more agressive stance. The bit that interests me is the intent from the factory when those (large scale) plans were done - that was a vision which got diluted in reality. We have now found that that with the early 65 drawing (which has nicely symmetrical rear wings wrapping around the wheels), that didn't really happen in practice until the 1936 cars. From a survey of quite a few cars, the very latest do appear to have wings whose design was obviously altered to realise the original plan, albeit when the car was almost finishing production!
