1933 RP Fuses
Good evening. I am trying to establish the correct value of the two fuses in the cutout/fuse box. Currently (no pun intended) the Auxiliary fuse is 35Amp the field fuse 8Amp. What value would they have been originally?
Personally I always advocate fitting individual fuses and relays for each circuit which can be discretly mounted.
I think they were originally 25A and 6A. I couldn't find any 6A so supply 7A instead.
Thanks David you have confirmed my thoughts.
Stuart
