Hi people
Can you give me some pointers as to why a 1932 Box Saloon should judder in reverse to the point that it virtually stops the car.
There are several reasons but what would your ports of call be ?.
22-09-2021, 04:45 PM
(This post was last modified: 22-09-2021, 04:47 PM by Chris KC.)
Do you mean when reversing Derek, or when braking in reverse?
"Rear Axle Tramp" is the first thing which comes to mind. I think our colonial cousins call it "wheel hop".
22-09-2021, 04:49 PM
(This post was last modified: 22-09-2021, 04:49 PM by Derek Sheldon.)
Yes Chris whilst reversing
Hi Derek
has been discussed on here a few times and seems to always come out as 'tramp' and a feature rather than a fault. My 33 RP does it. You can feel it lifting, especially if reversing quickly.
Andy
Indeed, to an extent I think it's inherent in the design; though obviously if rear axle & suspension bits are unduly worn they may exacerbate the issue.
Car type: RP Deluxe Saloon 1933
Derek,
I inadvertently cured my RP, which did the same, by changing to an SU carb. I found I was able to let the car tick over and letting the clutch out gently allowed me to reverse at slow speed perfectly.
It became a pleasure to reverse into the garage rather that being an exciting manoeuvre.
I hope this helps!
Roger
Thanks chaps
I think the word is: when taking off in reverse you should 'feather' the clutch.
Hi Derek
It is probably well worth checking that the brake shoe pull off springs haven't become detached at the fulcrum or the fulcrum itself hasn't come adrift.
The former was the cause when I first acquired my RP.
Good luck solving the problem.
Bob
