Just been out examining the front wings - underneath, right at the back, where they bolt to the running board steels. Cleaned away the mud and found rust just starting. Wire brushed it ready for Jenolite rust remover, primer and black. Quick and easy. Should nip the corrosion in the bud. The wing was repaired with metal being newly welded in 20 years ago - and was well protected at the time - but this is a prime spot to go again?
Wouldn't dare go near my car with rust remover.
After about 2 years of wire brushing, rust was finally banished from my Ruby - being rescued after 22 years in a garden it was becoming nothing more than a pile of rust so something had to be done - 'oily rag' was not an option - now I am trying to stop rust quietly returning, especially in the metal that was welded in, which is not as good as the original.
Remembering back to a comment I heard fifty years ago - It's all right, its got a chassis...
A "rust free" car must be up there with the unicorns and fairies. The tin-worm never sleeps...
"You buy a car, but you invest in an Austin!"
Colin
yup,
I've a car here restored circa 1978, in truth the connection between the wings and running boards is probably knackered. But the car is delightfully tatty so I'm not touching it yet.
A car restored in 1991 where the wings etc were religiously stuck together with tubes and tubes of tiger seal (by father), that is still very good.
A car restored in 2000, which I had someone paint for me. It seemingly has a bead of goo top and bottom on the joints and I will probably have to wire brush and de rust the lower surfaces for the 4th or 5th time soon. However I do occasionally use this car in winter. Which doesn't help.
