Half shaft
Went out in Crusty SWB 1931 today reversed  out the drive  engaged first gear  a slight knock and bingo no drive !! Halfshaft or key failure I suspect !!
Chris
Well you have done a mile or two Chris!
At least it happened on your door step...
Think the Flangwangle that connects the Donglewongler to the Clunchflipper is not engaging with the Plungecruncher or the Ploptumbler !!!!
