Oil Pressure Relief Valve
I am at last building up my 65 engine. I have bought a new spring and ball bearing for the oil pressure relief valve from a cherished supplier. Is my thinking correct that the ball should be seated against the aluminium crankcase by a smart tap with a brass drift?
That’s what I have always done Colin.
Cheers Ruairidh, that'll do for me!
