16-06-2021, 07:24 PM
Has anyone used a different valve guide from the standard cast iron ones?
Valve guides
16-06-2021, 07:35 PM
I had bronze (I think), inserts fitted years ago but they did not perform any differently - what are you thinking Robert?
16-06-2021, 07:47 PM
Manganese bronze guides.
16-06-2021, 07:50 PM
They could well have been that, they are still in the Ulster [sic]...
It was quite a bit more expensive than simply replacing the guides and they have worked no differently.
16-06-2021, 07:55 PM
But have you measured them for wear to compare with cast iron?
16-06-2021, 07:57 PM
Of course not!
16-06-2021, 07:59 PM
They’ve done about 60k without issue, but so have the standard ones in the Chummy...
16-06-2021, 08:03 PM
the only thing that would bother me with bronze, is like everywere else a bronze bush is used with a steel shaft.
it doesnt seem to reduce wear, it just wears the steel part instead of the bronze. nothing to worry about in any short term, but may need keeping an eye on in the long term. tony
16-06-2021, 09:08 PM
Hi All
Tony’s comment struck a chord. I’ve recently refurbished an FZ22 carb. I was expecting to have to bush the spindle but it turned out that all the wear was in the steel spindle and the carb body was as good as new. A friend suggested that the bronze/brass acts like sandpaper with grit embedded in it. Cheers Howard
16-06-2021, 09:26 PM
(This post was last modified: 16-06-2021, 09:29 PM by Hedd_Jones.)
Experience with steam bearings over many years has taught many of us that if using 'bronze' of unknown provenance (i.e offcuts from the scrap yard) often the shaft needs to be hardened to prevent issues. But particularly also with any of the 'PB' bronzes.
Preferred material is SAE660 (Leaded Bronze) if carving from solid, or One of the 'LG' leaded gunmetals if using castings. LG2 often. These have proven to be fine with the normal steels used by us for shafts. EN8. EN16, EN24 EN40 etc, there is a tendency for owners to use stronger and stronger steels, where EN8 is better than original spec. It machines better too, machining some of the PB bronzes is like machining snot. That said, I have no idea what a valve is made from, it might be hard enough for PB. |
