fuel tank drain
Can some one tell me what thread is used on the fuel tank drain plug on a RP, is it a standard BSP  fitting size.
Hi I have a feeling it's the same 3/4 inch 14TPI special as used for the sump drain plug, but let's wait till someone can confirm/deny this.
(15-06-2021, 05:51 PM)John Cornforth Wrote: Hi  I have a feeling it's the same 3/4 inch 14TPI special as used for the sump drain plug, but let's wait till someone can confirm/deny this.
Yes, John, you are correct.
