  • 1 Vote(s) - 4 Average
Quick ride today - noise from the gearbox...
Today, I took a quick ride in my A7. Just after starting I realized a noise from the gearbox area.
It is like a knocking, especially when I release the trottle - any idea what I should check first ?
It a 4-speed gearbox with a period remote lever.
thanks
Oliver
Does the sound go away when you push hard on the clutch Oliver?
Need to try again, but I think I had the noise when puahing the clutch for changing gears
Could be many things but possibly the front main lip gone or perhaps a loose flywheel?
